1 - 11 of 11 Posts
Hello
I have Pilot touring 2017, Live in Toronto where they through a lot of salt for deicing.
I used to do a weekly car wash in the gas station where they have a water pump underneath the car.
Is that enough? do I need to make rust check or undercoating once a year professionally? or Do it myself?
One more question: I have also Honda Civic 2012, should I do the same or something more as I believe the body protection technology in the pilot2017 could be more advanced than the civic2012.
BR
Omar
IMHO,
I just bought a really nice 2015 Pilot, low mileage, low rust, etc.
I many have posted that question here but,
after doing my own web search- I found that it's often not worth it, and a underbody coating, whether shop or DYI- Could even make it worse by plugging key drain holes sometimes.
YES, you should use the car wash often during the 'salt/winter' months for sure.
We'll see what other chime in on.
I live in Minnesota, where we also use a lot of road salt. My 2003 is still running like a champ, but rust has done serious damage to the rear subframe and hitch frame.
On my 2018, I am using a product called Fluid Film. It will soak into existing rust and slow it down, it creeps into pockets to protect the frame. Needs to be repeated every year or two. Looks like a good solution.
Road salt = rust. Get the car Krowned or Rustchecked before winter. It's the only rust protection that works. I had mine done back in Jan at Krown and it was only $100 with the CAA discount. If you are getting your car washed once a week, you are already spending over $100.
I did FluidFilm after not doing it to my Sequoia and having to get rid of it for everything rotting underneath.
If you have it done, watch and comment NOT to spray up in front of rear differential. There are some atmospheric sensors up there that might get clogged and trigger check engine lights. Dealer will say not covered under warranty due to excess undercoating causing the issue. :rolleyes::unsure:🤬.
I posted some pictures somewhere in here if you search.
Also woolwax (like fluidfilm) is an option. Same lanolin based stuff but darker color and from what they say is a lot less "fragrant" then the fluid film.
Yes, Fluid Film does have a unique aroma, but it is good stuff and I always keep a can in the shop and use it mostly on electrical terminals to prevent corrosion.
Two words..... FLUID FILM. It works wonders. I've been spraying everything metal the last 20 years. I spray my AC unit at the beach house, boat trailer, mowers, snow blower. Its just works!
Fluid Film Rocks
Thanks, I saved this page/product! Lanolin based.
I'll try it out on a few things for sure.
2020 Pilot Black Edition
No problem at all, I always buy a winter pass and go at least once a week
Oh awesome! That’s exactly what I do, have an unlimited car wash pass and go 1-2x a week depending how slushy or snowy the roads are and didn’t want it to wash off. This is definitely encouraging to hear! Sounds like I’ll be climbing under the car and spraying some fluid film!
1 - 11 of 11 Posts
