1 - 2 of 2 Posts
Im planning to build a good sound system in my 2016 Pilot, as well as placing a converter to 230V 300w AC outlet to be able to put a Playstation in the rear for BluRay movie watching and perhaps some playing while on long trips. I already have a 5m long gauge 2 (32mm2) wire that I’ve used for previous builds in other cars.
where do you recommend to rout the cable through the fire wall and to the rear?
On the driver side fender, remove the liner, there is a grommet that you can slice, it's for the the hood cable, that will run it down by the inside kick panel, then to the rear.
1 - 2 of 2 Posts
