1 - 2 of 2 Posts
I have a 2007 Honda pilot awd I just put a used motor in it with 120k on it, as soon as I started it up it idled rough then stalled within 30 seconds, if I hit the gas and bring the rpms up to about 2500 it runs perfectly smooth but as soon as I let off it stalls, after it warmed up, it stays running, idling rough, until I uit the gas again and let off, then it dies, I cleaned the throttle body, checked for vacuum leaks, and there are none
Traded Pilot for Highlander
It might be your throttle position sensor (TPS). I had that problem on my old Jeep Cherokee and the TPS was the issue.
1 - 2 of 2 Posts
