Upgrading the roof rack to run LEDS on top so where is the desirable location drill the hole to run the wires into the cab.
I was thinking of drilling the hole under the end cap with a rubber grommet and then drilling another hole for the exit on the side of the end cap.
This should keep the water/ snow / rocks / zombie fingers out.
On the other hand this would drill into the A pillar area ? .... not a good thing to do...?
Discussion Starter #2
Am I correct with all the guru's , mod masters and everyone else NOBODY installed roof lights on a Pilot ?
I'm shocked :D :xnuts:
Discussion Starter #4
Maybe the guy from this post has an answer for you.
Award For Most Lights
Yes true that it is ..I also saw this post but unfortunately the OP didn't explain where they punched through the roof without any issues with leakage .
Tons of sealant, prime and paint the bare metal of the hole plus grommet to protect wire on way in. Or plan B, run the wires clipped to the windshield.
