1 - 16 of 16 Posts
I have replaced vtec solenoid the whole unit but it's still giving me engine light and going into limp mode. What else can it be.
Year, 4wd or 2wd, mileage, and what code(s) does the vehicle have?
Yeah sorry about that. I just realized I forgot to put it on my post. It's a 2008 2 wd with 169500 mi.
One sensor came with the vtec solenoid is there two of them. If so where might I find it.?
You replaced this entire part with no results?
144907
That's correct
Was the battery disconnected when you did the install? If not, disconnect for a few minutes then reconnect and see if it comes out of limp mode.
Reactions: The Todd
It's going out of limp mode if I turn it off for a minute and start it again then it runs fine for a while then goes right back to limp mode.
Conections are oil free, clean and dry? No bent prongs.
When my Vtec was going out, it would fine for 20-30 mins. then go into limp mode.
But you changed it.
Can you go to an auto parts and pull the codes for it and get back to us? It's free there.
I haven't checked the connections closely yet I will try it and get back to you Thanks for the help this is driving me crazy but I really like the vehicle.
Hopefully something easy.
Sometimes after replacing, the filter screen can clog again.
I just noticed you posted the year, there are two oil switches on VCM engines 2009 on up, so you'd only have one on a 2008. Did you install the new one? Try changing the oil and oil filter and cleaning the VTEC valve screen.
Discussion Starter · #15 ·
Yes I'm doing this as we speak. I appreciate the advice very much and I will be sure to let you know how this turns out. Thanks
1 - 16 of 16 Posts
