probably a little ...."TMI" ..but here you go
Honda Pilot 2011 Wheel/ Rim Specs:
17" x 7.5
Bolt Pattern: 5 x 120 (5x4.5)
45 offset "H"
Center Bore: 64.1mm
stud size M14 x 1.5.......
torgue 80LBS
other wheels that fit ranges..that should work
  • Width: 235 — 265
  • Aspect ratio: 50 — 65
  • 235/65R17 — 265/50R19
Diameter: 17 — 19
Width: 7 — 8.5
Offset: 43 — 51​
enjoy..
FWIW, 5X120mm bolt pattern IS NOT 5X4.5”........114.3mm is 4.5”.
According to this website, the OE 2011 Pilot rim is 7.5”X17”.
The OP needs to look at the wheel info stamped on the backside of the 2011 Pilot rim and report back the rim width..........7" or 7.5".
