Has anyone found/know a way to use the Honda factory backup camera to work with aftermarket radio/systems ?
or, which Aftermarket audio/video system can function with the Honda factory camera ...
*2008 Honda Pilot EX-L w/NAVI
Wish I could help, but my backup system only works like this:
  1. Put right arm across top back of passenger seat.
  2. Let out a little old man grunt as I twist my body and turn my neck around to look out the rear window.
136988
You need to get your hands on a service manual for pinouts. On 2013, camera goes direct to the display module. On 2008, it will be on one of connectors to the nav unit. Camera will have video signal/video ground which are same as a regular yellow RCA composite video jack. Then there will be camera power and ground. On 2013 it is +8VDC, There is also camera signal shielding and camera presence (open = no camera, grounded = have camera - but you should be able to ignore it.)
Nav unit most likely gets reverse info from B-CAN. For aftermarket, you will need to tap a wire from fuse box that goes to the reverse lights.
