1 - 20 of 24 Posts
Greetings all. I replaced my original shocks and struts for my 06 Pilotwith a set from 1a auto and they are terrible! They are noisy as heck. I was thinking of buying another set of shocks and just dealing with the front struts. Anyone have any recommendations for the shocks? Don’t want to buy another pair of garbage. Thank you all in advance.
I put KYB front and rear on my 04. But I never use quick struts on the front. I just buy the regular struts and take them to a local shop to swap the springs for a small fee. The quick strut springs are never as good as the stock ones.
+1 on the KYB from Rockauto.
https://www.rockauto.com/en/catalog...on,strut+/+coil+spring+/+mount+assembly,15174
https://www.rockauto.com/en/catalog/honda,2006,pilot,3.5l+v6,1432632,suspension,strut,7584
Whichever you choose, they're currently both running a $25 Visa gift card promotion. As well, don't forget the 5% discount for members of this forum.
5% Discount Code: 6F3FAEF349C046
Expires: February 12, 2020
Another vote for KYB.
Did anyone use Sachs from RA on the rear? How did they hold up?
Do not buy Off Brand shocks and struts. They have some great deals at Rock Auto, stick with Gabriel, Monroe, Sachs, or KYB, although I put Bilsteins on the BMW (German made). The FCS and other Chinese brands are mostly garbage, and the cheepest Monroe will outperform the top end Chinese garbage.
KYB is now making quick-struts, those might be a good deal - more research is necessary.
I wish Bilstein made struts for Pilots of our generation!
They do ... oh wait that's for the second gen my bad ... carry on :)
2010 Pilot EXL
I disagree. In my experience, the kyb quick struts have better springs than originsl. Way better than rusty original. Here in mn, we often have broken honda springs from winter and potholes.
Try Newyork we don't have pot holes we have craters
Does anyone have experience with purchasing and installing air bag helper spring inside the rear coil springs like th Firstone Coil-Rite?
Alternatively, has anyone found and installed rear shocks that are wrapped with springs (like for towing). I'm interested in ways to get rid of the rear sag on my pilot, which is not something that is correctable from standard shocks (just replaced with Gabriel shocks as it was due). I really don't want to replace or even remove the rear coil spring. Did this on a 2011 and can't imagine the further issues on a 6 year older Pilot that has been exposed to midwest winters. Thanks!
Link for coil rite: https://www.sdtrucksprings.com/inde...MIo8Lm7rSc5gIVTvDACh14xQMcEAQYASABEgKPevD_BwE
So one thing that is making me think about the OP. What kind of noise are you getting that is being attributed to the shocks? Rattles can be cured with a thin washer between the eye bushing and the hanger. Squeaks are often the bushings or spring insulators. Clunks are the strut mounts. A brand new shock or strut, if not blown or leaking, will not usually make any noise.
When it says these have 500 to 1000 lb capacity how does that get calculated into towing or hitch weight capacity with a vehicle that can pull more than that?
That is the amount that the bags can lift at max pressure. It is only adding a way to level your vehicle out better when under load. Even when you are below weight capacity (1000 lbs for a 1500 lb capacity let's say), your vehicle can still 'sag' - this is where these would come in to help correct that.
Buy the Scotty Kilmer t-shirt!
1 - 20 of 24 Posts
