1 - 1 of 1 Posts
Last year I replaced a torn center console cover in my '12. I finally got around to replacing the torn driver's door armrest cover. I used this kit:
The instructions I used came from here:
The only difference for me was I did not detach everything and take the door panel completely off. I was able to get to the armrest screws after I got the panel off the door but leaving the wiring attached. The console in the door with the door lock and window buttons you need to pry it up from the end opposite the buttons. When you put it back there's a clip towards the front that has to go in first before you can clip the other end down. When you're peeling the old cover off, make sure you don't peel the backing foam off with it.
Before
147556
After. Not perfect but it looks a whole lot better. The next step is to clean all the upholstery.
147557
1 - 1 of 1 Posts
