1 - 2 of 2 Posts
My Pilot came with the door edge films and door handle films installed: in the door edges (in case I hit my doors with something else?) and behind the handles (to avoid scratching them with... Rings?). While the first ones are barely visible, I’m thinking of removing the films that are behind the handles. Can I just peel them off safely, or do I need to apply any kind of heat or product?
Thank you.
Looking online, it appears you can heat them up with a hair dryer, get your fingernail under a corner, and then carefully peel it back while continuing to apply heat. But don't use a heat gun - that would be too much heat.
Another site mentioned using a steamer like you would for wallpaper, but I suspect it is just the heat that you want.
Good luck.
1 - 2 of 2 Posts
