1 - 2 of 2 Posts
I have the 2018 EXL with remote start. I've noticed when I use the remote start with the AC set to full blast it doesn't actually turn the AC on. Is there a setting I can change for that? I have dogs and want to be able to cool the truck off before I put them in there.
Not that I have found. I tried the same things and determined the vehicle ignores the last climate control settings. Then I read the manual (should have been first step...) and found:
While the engine is running, the vehicle will automatically precondition inside the vehicle.
When it is warm outside: • The climate control system is activated in recirculation mode. • The seat ventilation is activated*.
When it is cold outside: • The defroster is activated at a moderately warm temperature. • The rear defogger and door mirror heaters* are activated. • The seat heaters* and heated steering wheel* are activated.
1 - 2 of 2 Posts
