Finished a clean install of the Redarc Tow Pro Elite on our 2019 Pilot yesterday, patted myself on the back and enjoyed the evening. Later, after dark, I noticed the tail lights were blinking intermittently while the car was off. Unplugged the controller and the blinking stops. A web search revealed this to be a sign that the brakes have been tampered with. Has anyone had this problem? Picking up a trailer in 4 days or so and this has me worried.
Thank you.
Sorry so late with the reply. I had mistakenly swapped the red and blue wires. After metering for 12v across the red wire when braking, all is good and no more blinking taillights.
I've attached pics of the correct wiring and also install of the brake controller switch using the Honda Pilot switch plate. The Honda switch plate in the 2019 Pilot can be drilled through and hollowed out on the backside, leaving just enough room for the switch to squeeze into place.
I'm very happy with both the product and the install.
137523
Vehicle Car
