1 - 20 of 36 Posts
My Mom and Dad bought this car new in 2005 and now has 160k miles and were terrible with the maintenance of the vehicle. The car has been my college age sister for the last 5 yrs. Almost all maintenance has been done by me here and there when I had time but I have a family and three other cars so this has been a pain.
The car still runs fine and I've done a few things in the last few years:
1. Catalytic converter from Honda
2. Transmission drain and fill
3. Battery and alternator
4. Front brakes (duralast gold disks and Bosch quiet cast ceramic pads) I did bleed them well.
5. Passenger drive axle replaced due to a broken CV boot
6. Drive belt 6-7 yrs ago.
Other than sporadic oil/filter changes by me and jiffy lube, this is ALL the maintenance that has been done. No check engine codes except for a bad wheel sensor and the car drips no fluids at all. Can you folks recommend further maintenance? I assuming all fluids need to be changed again, thermostat timing belt and water pump kit. But what else? Its been neglected for far too long! Help Please!
If the timing belt hasn't been replaced in the past seven years (or ever), then do it today.
Check for any open recalls - especially for the airbags:
Recall Information for Safety & Defects | Honda Owners Site
Follow the maintenance schedule in the owner's manual:
http://techinfo.honda.com/rjanisis/pubs/OM/AH/A9V0505OM/enu/KV0505OM.PDF
Or, use the one in this thread:
Maintenance Minder - Updated
The radiator is a known weak point for the 2005 model year.
Replacing it proactively is advisable.
Other than the timing belt, it hasn't really been neglected. These cars don't require much. Oil, transmission fluid and timing belt are really the most important. Rear differential fluid if it has VTM-4.
Any maintenance performed on rear diff, T/C, radiator/coolant, inspect for rust ?
I dont think any of those things have been done. My dad swears up and down he did the timing belt and water pump from some side work a honda tech was doing. Lol
It might indeed be wise to replace it as cheap insurance against a potential catastrophic transmission failure.
140120
You can get a good Denso radiator from Rockauto for a good price.
More Information for DENSO 2213232
You can even use our Piloteers discount code.
5% Discount Code: 3AE5CBE8F18A03
Expires: November 12, 2020
Common failures for the 2005 Pilot are the radiator (mixing coolant and tranny fluid), the front and passenger side motor mounts, and the lower control arm compliance bushings.
2005 is also the only year Pilot which has an internal serviceable tranny filter (which doesn’t require engine and tranny to be separated). I’ll be changing mine out later this year.
And don’t forget to vacuum the dust from the rear blower filter screen.
Reactions: skycamper
And welcome to the forum.
Good and often neglected advice, it doesn't appear in the owner's manual. It'll save you from scratching your head one day wondering why the there's no air, hot or cold, blowing out into the second row (spoiler: that thermistor, aka thermal resistor, aka thermal cutoff, aka rear power transistor, blew). The hardest part of this job is just finding out about it and then finding it. :)
To clean the rear blower fan, move the driver's seat all the way back, then remove the driver's side panel under the center console between the driver's seat and the gas pedal. The panel just snaps out and it's easiest if you start pulling near the gas pedal.
140126
140127
Discussion Starter · #14 ·
I will do the fan thermistor on the next oil change and clean the fan! This is gold! Thanks! One more question. This car is actually at 144k and I keep reading that the radiator and transmission are connected and when the radiator fails it screws the tranny. And this is noticed by a strawberry milkshake in the radiator overflow?? Is this true?? I have a 2013 pilot for my family as well and is this also true for that model year??? Who would design something to where if it fails it ....it causes you to replace two expensive components of your car and leave you stranded?
Does replacing the radiator now keep this from happening? How would that be? Is the problem within the radiator itself and not some coolant lines in another part of the car?
Replacing the thermistor is not necessary if the fan is still blowing. Just vacuum the dust on the mesh in front of the fan to improve airflow and reduce the chances of the thermistor failing.
Yes. 2005s are more prone to this.
No.
Bad engineers or planned obsolescence executives, take your pick.
Fortunately, yes. OEM Densos were slightly redesigned, I believe, to Honda's credit.
The problem was where the coolant lines and ATF lines enter into the radiator, causing coolant and ATF to mix, hence the "strawberry milkshake."
The original radiator in my 2005 and the OEM one I replaced it with had two different part numbers leading me to believe Honda/Denso identified the failure point and resolved it. There are far fewer reports of the pink milkshake on non-2005 Pilots on this forum.
If you decide to replace the radiator you might as well replace the thermostat, its gasket, and two radiator hoses while you’re in there.
Discussion Starter · #17 ·
Good point, In getting ready for radiator replacement. I'm thinking of hoses. At Rock Auto I see the brands from Gates, Dayco, ACDELCO , Continental. Theyre all about the same price. Are any of these OEM ? Another source? Id like to have a new cap and T-stat as well. I'll keep looking unless someone can suggest an OEM brand.
Along with the Denso radiator, I got Gates upper and lower hoses and thermosta, all from Rockauto. Been fine so far.
Yeah, ditto on the radiator. I had a 2005 up until 2 years ago until I got a 2017. I replaced the radiator AND the whole transmission. (Ideally, you won't need tranny. That's a hit or miss dice roll thing that could last decades... or not. But... mine went bad.)
The radiator hoses were mentioned, but carefully check every hose you can. Hoses are generally fairly cheap. (Though getting to some may be challenging.) But over time, and weather cycles, these can become brittle or the connections can become loose. All of a sudden, a stupid $15 part with a $1.00 clamp gets you stranded or through failure damages some other more expensive part.
1 - 20 of 36 Posts
