I'm looking at Carfax report for a 2019 Touring. Below is the recall notice on Carfax:
Recall Date: 9/10/2019
Recall #HO18 Incorrect Time Displayed on Cl This recall was open as of the date/time that this report was generated. For more information, or to find out if the recall has been closed, please contact HONDA.
Is that a major problem?
Not sure if it's related, but there was fix related to the clock being off on some cars in an update from August last year: https://owners.honda.com/Documentum/ota/2019_Pilot.pdf
Was not a recall, its TSB 19-096 software update thats received over the air to fix 'The Display Audio screen may show the clock off by 1 hour.'
It's no big deal if your clock is showing the correct time, ignore it.
The fix is a software update for the entertainment unit, and a 10-min fuse-pull to drain the onboard charge and make sure it fully resets itself.
The TSB does nothing else, it's not critical if you don't have the incorrect time issue.
