1 - 2 of 2 Posts
My passenger side rear window dropped down and won't come back up - the motor is still working.
I saw some videos on replacing the regulator but was wondering if anyone was able to fix it?
See the video below of my door, it seems the top spring is not doing what it's supposed to. Unfortunately that spring is behind the glass and I can't reach it unless I take more things apart, probably remove the regulator from the door.
In the meantime, any way I can at least get the window up and hold it in place closed? Currently it won't get passed 1/3 of the way up.
https://youtu.be/_e3BDBIhvTU
We replaced the window regulator on the pass. rear fairly easily. Used a piece of wood to hold it up till fixed. Hope this helps :)
Used a video like this to replace the motor
YouTube
1 - 2 of 2 Posts
