just installed splashguards with no surprises. The tire restricts access to the lowest screw (even if using a "stubby" phillips). I was able to use on of those "crooked, Z type" screwdrivers to get it started. By end of tightening this screw, stubby will fit in for final tightening.
Removing wheel would make job very easy. However, I found that jacking up car (to point where tire almost left ground) allowed enough access for the Z type screwdriver. Probably not a bad idea to famililiarize oneself with jack operation in a nonemergency, daylight situation. I did have to loosen jackscrew to be able to remove it from its storage bin.
In summary, this is less than a "one beer" job...on a cool night, anyway
