1 - 13 of 13 Posts
Front doors and tailgate actuate fine, rear doors sound like they're activating but do not unlock or lock the door. In fast, I am seeing the lock buttons vibrate when activate the locks. Right now I just manually lock or unlock the rear doors using the button on the rear doors. Not a bad issue, but one of convenience should I be able to fix it. Tldr: lock actuator working, door not locking from it.
First thing to try is to shoot a whole bunch of silicone lubricant spray in there and keep cycling it manually several times to see if that decruddifies it.
In a pinch, WD-40 will do.
It is odd that it is both rears that are acting up. Are you the original owner, or have they ever worked since you have owned it? I would look to see if the rod is disconnected.
Discussion Starter #4
No I just bought this Saturday used. That is my suspicion, I will check it out. Hopefully that's all that's happening. Thanks, Will update soon.
Discussion Starter #5
Haha, I'd agree, but I can hear the actuators activating, but it seems to me that they and the lock rod arent connected.
Ah, new to you. Indeed odd that a mechanical failure occurred on both rear doors. OK, time to open them up and have a look-see.
It’s probably not this, but try toggling the white child door lock switch on the rear doors. Otherwise sounds like you’ll be taking the door panels off. Good time to replace the rear speakers or rear door checkers if necessary since you’re in there.
Discussion Starter #8
I haven't even thought of that yet, I'll see what happens
Discussion Starter #9
So tonight I removed the rear driver side passenger door panel, then toggled both the lock button on my key fob AND on the door. I discovered that there was no reaction from the actuator. I imagine it is the same on both sides and in this case, I misheard the doors actuating. What else might it be? If it was a fuse blown, which one is for the rear power locks? I didnt have enough to buy the Haynes/Chilton manual yet.
I've highlighted the fuse locations for you.
My SWAG diagnosis? Previous owner spent an inordinate amount of time yelling, "I've told you kids a thousand times not to constantly play with the power windows!"
If you have a multimeters might start looking for power and ground connections to the actuator. You might also try removing the actuator and bench testing it. If the actuator is good one cause could be a broken wire or two between the cabin and door within the rubber wire boot.
Discussion Starter #12
Thanks a mil, I appreciate this!
Discussion Starter #13
I hope it isn't ugh, I'll crack it open and pull the actuators later this week haha
1 - 13 of 13 Posts
