1 - 20 of 21 Posts
2004 Honda Pilot EX-L and 2019 Chev Corvette 2LT
Took my car to the dealer because the rear A/C fan was inop. They diagnosed it and said the fan motor was bad and said it would be $800+ to fix it. I called BS and left. Bought a new fan for $143 and installed it in maybe 20 minutes, very easy. Still didn't work. Ordered a new transistor for it and now waiting for it to be delivered. So I guess the dealer didn't diagnose it properly or the fan AND the resistor were bad, not very likely. If the resistor solves the issue I many put the old fan back in and return the new one I just bought. The only reason I did the fan first was because of the dealer diagnosis. Would have loved to do it in reverser order. Live and learn.
Discussion Starter · #2 ·
And man oh man what that screen clogged up too. Wow
Yeah, I was going to mention clean the filter screen after seeing your initial post. That’s likely the reason the transistor module died, due to lack of airflow across its cooling fins.
And welcome to the forum. Glad you’re fixing it yourself instead of having the dealer perform the work.
Thanks very much. I would bet you're correct about the module. I'll follow up when I get it and install it
It's quite simple, they lied.
They quoted you worse case scenario and never really checked anything.
I find it disappointing that the Owner's Manual doesn't mention vacuuming the rear blower screen as a maintenance item. It's not that hard and pretty much just involves pulling a clipped panel by hand. I'd have it listed at the same interval as changing out the cabin air filter.
But that would mean less money for crooked dealerships, if you'll pardon the pleonasm.
135613
135614
2006 EX-L RES 2WD
I've been thinking about this on and off. Mine is starting to blow less air out and now I know what to go do before it breaks.
So first just start pulling out by hand that clipped-in console panel by your right foot, starting up near the gas pedal and working your way back toward the driver's seat, which you should slide all the way back for better access, and then vacuum the blower motor screen. If it's never been done, it might really need it.
Hey, why not post before and after photos?
2006 EX-L RES 2WD
I will definitely post before and after photos for y'all. I'll hop on it this weekend.
It's a great feeling, isn't it? (y)
Mine still works fine, but I actually bought a spare transistor (they're not that expensive anymore) which I have on standby for if the time ever comes.
Discussion Starter · #15 ·
Not a bad idea. I think I’ll just keep the fan as a spare.
I replaced my relay about a year ago and all good. I noticed again no air and it seems to be in the harness plugging into the relay. I can squeeze/ move around wires and get fan to come on. Ideas before I start unraveling harness tape? Thx
Wires in the conector could be corroded. Try spraying CRC Electronic Cleaner into the conector, let dry thoroughly.
Discussion Starter · #19 ·
I like putting Dielectric grease of on electrical connections also. Glad you found the issue
I have an UPDATE! Got the transistor today, installed it and with the now clean screen the rear fan blows force 10 air! I'm a happy Piloteer. :D Thanks to everybody for all your help with this
Can you link to the transistor you got? I have the same issue. Bought a cheap one on amazon and it didn't fix the issue. Not sure if I got a bad transistor or have another problem.
1 - 20 of 21 Posts
