1 - 1 of 1 Posts
I have a 2007 Pilot 2WD and I tried to change the rear mount in my driveway. I did the front pretty easy (took out from top)but the rear was difficult to get the 4 bolts loose, because you need to get a thin wrench in to hold the bolt, while you loosen nut, then once they are loose, pick up the mount over the 4 bolts seems impossible. Anyone have a video how to do this? I did jack up the car and lift the engine a bit, but nothing helped. I’m stuck. I have looked at YouTube and they have how to change others, but my engine mount is different.
Thank you,
Tony
1 - 1 of 1 Posts
