2012 Honda Pilot EX-L
I’m trying to troubleshoot an issue with my passenger rear door handle where it won’t open. I have the door handle free, but there is a rod that connects it to the locking mechanism and I can’t seem to get the rod free from the socket.
Anyone come across this? How can I get this rod free from the door handle?
There is usually a plastic retainer clip over the rod which you have to gently pry loose with either your fingers or a small flathead screwdriver, then rotate the clip so you can pull the rod free.
Reactions: Nail Grease
Something like this I believe.
141332
After more research, the handles used on 2012 (and likely thoroughly 2015 but unconfirmed) are the same as 05-11 Civic handles. I found the part I needed at a local salvage parts yard, full handle for $25.
I found this video helpful to get the job done:
Thanks for all the input!
