1 - 2 of 2 Posts
· Registered
Hi
i have a leak at the rear differential at CV axle connection, passenger side . Its probably the seal inside the differential but as its a very labor intensive repair (was quoted 600$ to change a 20$ seal), i want first to explore other possibilities.
it doesnt seem to come from the pressure sensor above, could be a clogged vent /breather ?
Automotive fuel system Automotive tire Motor vehicle Tread Automotive exhaust
Honda Pilot 2018 - AWD - EX-L
· Registered
Are you under 60000 miles? If so should be covered by the Honda Powertrain Warranty for 5 years or 60000 miles on your 2018.
On your transmission, the warranty covers the outer transmission hold and every part within, the torque converter, the transfer case and the parts within, the control module, seals, and gaskets.
If you have a front-wheel-drive Honda, the warranty covers the case for the drivetrain and the parts within, the driveshafts, CV-joints, hubs and bearings, seals, and gaskets. Rear-wheel-drive models have warranty coverage on the rear-differential case and the parts within, propeller shafts, U-joints, driveshafts, CV-joints, rear hubs and bearings, seals, and gaskets.
1 - 2 of 2 Posts
