My 2013 just hit 60k so I'm researching on changing all of the fluids (except brake fluid which I have already done). I've found the videos on how to change the differential fluid but just wanted to confirm that the crush washer for the transmission will work on the differential? I'm going to buy a pack of 4 for the trans and from the best I can tell the they should work on either the trans or differential but just wanted to get a confirmation if someone knows for sure.
Engine oil drain plug washer - 94109-14000 (14mm)
Transmission drain plug washer - 90471-PX4-000 (18mm)
Transmission fill plug washer - 90441-PK4-000 (24mm)
Transfer Case - 94109-20000 (20mm)
Rear Diff drain plug washer - 90471-PX4-000 (18mm)
Rear Diff fill plug washer - 94109-20000 (20mm)
Hey caverman, just curious. Did you replace the crush washer on your transmission fill bolt? Parts sites are telling me the 24mm 90441-PK4-000 doesn't fit the 2013 Pilot.
