I'm pretty sure I need to replace the rear air blower motor, but wanted to double check first.
Have a 2008 EX-L with 188k miles that I bought last summer. Noticed a month or so ago that the backseat doesn't get air. I replaced the transistor and now if I turn the fans ALL the way up, you can get a trickle of air in the backseat, like what comes out of the front vent on the lowest fan setting. I cleaned off the (filthy) air filter when I replaced the transistor. I checked on the rear blower motor and noticed that it does vibrate when the air is on and vibrates more when I turn the fans up to max, but again, back seat isn't getting the airflow I'd expect.
This sounds like a rear blower motor issue, right? Or should I troubleshoot some other area first?
