I just changed both front brake calipers and flushed the brake fluid on my 2006 Pilot. Now it's shaking and rattling at freeway speeds, but stops when the brake is applied. What could I have done wrong?
Well, ya screwed something up. It was quiet before, and now the calipers are loose. Because this is brakes, just bring it to a mechanic and have it fixed. Let him tell you what the problem is, but don't keep on driving.
Can you tell what side is shaking? Take the wheel off and inspect your work. Check the torque on all your bolts. Make sure tires are mounted flush on the hub.
Reactions: aggrex
It sometimes even helps to clean or sand off the rust or crud on both those mating surfaces,
