Does any one have an issue with a noise that sound like LEGOS being tossed around coming from the driver's side door ? I have checked and there is nothing that is loose in there door well etc. Please provide a TSB if there is one.
Miss our 2005 Pilot
Did you remove the door panel
and the speaker to get a better look inside the door? I wonder if one of the many wire harnesses isn’t secure and is bouncing around.
I have done that it seems like it's coming from the door handle but when i pulled that out it didn't seem lose or anything . I even added poly urethane padding on the metal just in case something would wiggle and hit against it while driving.
Miss our 2005 Pilot
Can you reproduce the noise if you slam the door shut fairly hard? That could help pinpoint where the noise is coming from.
