Premium Member
Radio switches to Aux mode w/o being prompted. Hit a bump, it switches. Stationary with radio on , it switches. Issues with radio before where panel buttons would not work, but wheel buttons would. This happens a dozen times a year or so. Any suggestions? Thanks
Depending on your comfort level you might consider taking the radio out and taking it apart. If all the radio front panel buttons are flakey I suspect there is a loose harness connector inside the radio. If you do take it apart take photos along the way so you know how to put it back together. If the Aux function is its own button try cleaning its associated switch with isopropyl alcohol while the unit is disassembled.
