Happy new year to everybody!!! Could you please help me to find a wiring diagram for a radio unit, honda pilot 2012? 39100-sza-0211-m1
The unit you mention is a regular non-nav model. Has quite a few connectors. It might be best if you state directly what specific functionality you are after.
The audio unit (looking from back) has 5 connectors along the bottom, A,C,D,E,G, and one connector F above those
Connector A (24P) is power, steering wheel and speaker connections.
C is mainly communication bus to other components, i.e. XM.
D is compass, Aux jack, phone (handsfreelink) and B-CAN
E is subwoofer output, active noise cancellation, PCM
F is mostly for rear entertainment system (if equipped)
G is antenna.
It might also be worth it to check out Do it Yourself Automobile Repair Manuals - Mitchell 1 DIY
There, you can subscribe for access to all service manuals for a specific Pilot model, only about $35/year.
Thanks)) I just need a scheme for connector "A" 24pin, my pilot is european, but units are American, I've found a scheme only for european versions(((
From wire side of connector, locking tab up,
AUDIO UNIT CONNECTOR A (24P)
Cavity​
Wire Color​
Terminal Name​
Description​
A3​
LT BLU​
K-LINE​
Detects scan tool signal (serial data)​
A4​
LT GRN(1)
SCTY​
Security signal from rear controller and screen(1)
RED(2)
Security signal from MICU(2)
A5BRNREMOTE GNDAudio remote switch ground
A6BLURR SP-Outputs sound signal for Right rear door speaker
A7REDRR SP+Outputs sound signal for Right rear door speaker
A10BLURR SP-Outputs sound signal for left rear door speaker
A11REDRR SP+Outputs sound signal for left rear door speaker
A12BLKGNDGround for audio unit (G502)
A14PURACCPower source for accessories
A16PNKREMOTEDetects control signal from audio remote switch
A18BRNFR SP-Outputs sound signal for right front speaker(s)
A19REDFR SP+Outputs sound signal for right front speaker(s)
A22REDFL SP-Outputs sound signal for left front speaker(s)
A23BLUFL SP+Outputs sound signal for left front speaker(s)
A24WHT+BContinuous power source
(1)With rear entertainment
(2)Without rear entertainment
Scorr
Cavity​
Wire Color​
Terminal Name​
Description​
A3​
LT BLU​
K-LINE​
A4​
LT GRN(1)
SCTY​
RED(2)
Scorrpio, can you tell me on a 2013 EX-L non-nav non-entertainment where the Amplifier is located? if you see my recent thread I am in dire need to find it and can't at the moment. A local Sound Pro wants nearly 500.00 to install amps that were not purchased from them. I am very experienced with install, but I am having a dickens of a time finding the darn Amplifier. Thanking you in advance.
Eric
The factory amp is under the dash on passenger side, below and to the right of the glove compartment. (See attached pdf)
For pinout, see this post
By the way, if it is a non-nav and non-entertainment, (no satellite speakers on rear columns) then the 'stock amp' is the head unit itself, subwoofer channel included. There would be no external amplifier box.
