My aunt's 2015 SE 4WD with 133k miles needs a new passenger side radiator fan as it's loose about half an inch play causing a noise. Looking at the parts diagram, I see that the fan and motor are separate items, which one should I order to fix the loose issue? The motor powers on as usual and as far as I could tell the securing nut is tight. I'm thinking the motor?
Fan: 38611-RYE-A01
Motor: 38616-RN0-A71
My first guess is it’s the bearings in the motor. But also check that the nut which holds the fan blades to the motor is tightened sufficiently.
