1 - 20 of 22 Posts
Since there is a known problem with the internal trans lines failing in radiator, should I buy an aftermarket radiator with a good reputation (which one is that) or buy a OEM Honda radiator assuming the design has been updated. I have an 07 with 160k miles.
That was only for the 05 series so interesting to know where you got your information ..didn't know they pushed this to the 07 series ..
Preferred aftermarket brand is Denso.
I’m pretty sure Denso is Honda’s OEM radiator brand. I used Denso when replacing my 2005 Pilot’s radiator. The part number was different compared to the original.
Reactions: vwvannut
Denso or TYC from RA.
I seem to recall a discussion about the troublesome fitting pictured in both below, and about which was better to avoid the pink milkshake of death based on the materials used in that fitting, but I can't recall the conclusion.
133477
133478
Discussion Starter · #11 ·
I assumed all first gens. Do you have any data suggesting the problem was resolved?
Got two 06 series both have original rads both have over 250k so I assumed the rad as redesigned since other than maintenance no leaks or issues
Do you guys/gals like the Spectra radiator? I was looking at the Denso on Amazon and noticed several reviews of being shipping a bad/leaky radiator. But these are from 2019 so maybe it was a bad batch?
I know people recommend Rockauto but I struggle with their circa 1999 web site! :)
I went with a Denso radiator from Amazon. Amazon allowed shipment in the original thin cardboard box with a few foam blocks. First shipment was wrong model# with bent metal trans lines. Second shipment shipped similarly was the right one. Swapped for the best metal trans lines before shipping the wrong one back. Amazon shipped quickly but I heard RockAuto double boxes....ymmv
Got my Denso from Rockauto. It arrived well packaged and undamaged, even through the last mile was via dogsled up here.
149166
Here, I’ll save you the trouble of drilling down on the RA website :):
RockAuto
And of course here's the Easter egg 5% discount. :)
5% Discount Code: 6E3EAFAFB9DB15
Expires: August 12, 2021
1 - 20 of 22 Posts
