Hello everyone, new to the forum.
Can anyone tell me which wires to tap into? I can't seem to figure out which ones are ground/power with my voltmeter...
Here's what my pin looks like. It's on a 2021 SE, and thank you in advance for any help!
140311
It does have auto start/stop, so am I out of luck here?
You most probably are fine, as long as you disable that "feature". There's a pinned thread which explains how to permanently disable it, or you could just push the button every time you drive. Don't take my word for it tho. Let's see what other people say about this.
Over 170 posts and suggestion in this one thread regarding how to wire a dash cam. Radar detector should be the same for power. Remember though that the wire colors may/do change from year to year, so verify what is where with a tester.
Hard wire dash cam/radar detector
I used the fuse box empty slot by the driver's left foot and a ground by the brake pedal mounting bolt. No problems with the Start/Stop on my 2019 Touring from that location.
