When I click on "AUTO", should it automatically function with the proper cooling temperature? I tried it today (my 2nd day with the Pilot), and it was blowing "fan" type of air (not cold at all). So I clicked A/C On , and it was doing the same thing (not cold). The temp reading was 65. Then when I hit RR A/C manual - the A/C kicked in....hmmmm interesting???
I used to drive a a 98 Accord EX-V6 - and from what I remember, I don't need to hit A/C, as long as my temp reading is under 68 degrees - I had an A/C type fan......
What do you do to get cool temps?
Thanks,
Jason
'03 Pilot EX-SS (day 2)
'02 Mercedes Benz C240
'96 Toyota Camry LE
Jason,
I don't think that is normal. You should get cold air without rear manual off. You might wanna give it a few seconds longer on auto, if it still does not give you cold air have it check.
Good Luck!
Thanks for the input Vegasdude....things were working fine with the AC today - I'll keep an eye on it.
Jason
