I am considering a 2014 Touring (100K miles) and am concerned about all the technology this car has. Is there a pattern of failure with say the cameras, sound system, AWD system ......?
That'll never happen until you manage to suppress the urge to push for Valvoline ATF.I guess I should have asked if the timing belt job has been done.
Always a heckler in the crowd.2nd Gen Pilots are fantastic vehicles, but they can be a little pricey for the "must do" items - timing belt and VCM disabler.
If you really want to get the most of it, the rest of the maintenance items are pretty straightforward for DIYers - transmission fluid drain and fill (I recommend 30k intervals, maybe a 2x or 3x right away to get it caught up), transfer case fluid, rear differential fluid (recommend 30k intervals as well, it's really easy and it's where the magic of this excellent AWD system happens). Brake fluid, coolant should be done at the timing belt, power steering fluid (I suck the reservoir dry with a turkey baster at each oil change and top it off with fresh) should all be done by now.
Common failure points are fairly minimal, the VTEC solenoid can spring a leak (it's right next to the dipstick tube in the head) and if not caught pretty quick it takes the alternator with it. The gen 2.5 ('12-'15) don't have as much of an issue with compliance bushings in the suspension but not unheard of. The rear shocks have a captive fastener (can't remember if it's a nut or bolt) that causes consternation. Some have had intake tubes crack causing some funky behavior but not codes (this is seen throughout the automotive industry with plastic accordion tubing).
My wife loves hers and probably will not be handing it down to our oldest in a few years, she'd rather get her something else rather than give up her car.
Man you two are ruthless with each other.
Don’t be afraid to lay under the vehicle and inspect for rust, especially if you live in the rust belt.Thanks for all the feedback! My first priority in the purchase of this vehicle was to avoid - DI, CVT and cylinder deactivation - so 2 outta 3. I won't be doing much of my own wrenching, but I have an honest and economical shop for the heavier lifting. Indeed new timing belt, all fluids swapped and install of a VCMuzzler II (or other recommended?). There's just no way to check everything when buying one used.
Looks like someone added hood struts. You?We just BOUGHT our "new" 2014 Touring a few weeks ago. It wouldn't gave sat at the dealership for a day. I spotted it on their website and showed up before they opened while the vehicle was still being serviced. Under 80,000 miles and extremely clean in and out. View attachment 184998 View attachment 184999
Correct. Out of the set it and forget devices, it is by far the best quality.So I'm to gather that the VCMTD1000 ($144.95) is the latest, most reliable "plug and play" muzzler that is the right application for the 2014 Pilot .......
Eek. After reading the VCM Mega post - I think I'm going to be following those directions ASAP. Thank you to all who have encouraged us to do this.I have a 2014 Honda Pilot EX-L 4x4 - and am the original owner. I still have the VCM running and it 🤞 still works well.
