Past wire corrosion. First pic is BMW engine-to-frame and next pic is Pilot trans-to-frame
Ahh, everyone loves the classics.Past wire corrosion. First pic is BMW engine-to-frame and next pic is Pilot trans-to-frame
The article mentions braided wire then ends with this: “Finally, insulated wire is best if you’re running wire for any sort of length. Insulation ensures that the wire will not deteriorate due to moisture”. Think there is a typo with using 14 gauge wire.also anyone interested in grounding a DC electrical circuit on any vehicle read this...
How to Properly Ground An Automotive Electrical System
Proper electrical system grounding is widely misunderstood. Here's a guide explaining precisely how to ground your vehicle's electrical system.www.hotrodwires.com
There is one pic of the Pilot trans to frame ground wire but there is also an engine to frame too as well as another. The first pic with the broken woven wire is from a different vehicle.@aggrex Where precisely is this ground cable you replaced? I already did the upper one, accessible from the top, near the battery. But the old cable didn't look like the one you have pictured.
not necessarily because that ground strap will only be handling the electrical current of any sensors and switches that happen to be mounted nearby.Think there is a typo with using 14 gauge wire.
Heat could melt the insulation? I haven't dealt with this on modern vehicles but on classic cars this is a common mistake people make, the engine gets grounded to the chassis via straps from the back of the valve cover to the firewall and from the front of the engine (water pump bolt for my Impala) to the battery.The article suggests braided copper for engine to chassis, but doesn't say why? I assume the concern is moisture can get inside a covered cable?
On the Honda, the strap is attached at the starter. Can't really say heat will be a problem for it. 🤔Heat could melt the insulation? I haven't dealt with this on modern vehicles but on classic cars this is a common mistake people make, the engine gets grounded to the chassis via straps from the back of the valve cover to the firewall and from the front of the engine (water pump bolt for my Impala) to the battery.
@dr bob has to know, he's our retired engineer that knows everything about everything. (that's a compliment, not sarcasm)
Should the insulation melt, the wire will retain a good connection but become exposed like the naked OEM woven strand wires. Some protective wire wrap should help.Heat could melt the insulation?
Since the engine (motor) wiring harness is mostly covered with plastic insulation not sure if the ground connection is any less/more vulnerable to moisture. OEM ground wires tend to be woven or braided bare wire possibly for flex from engine (motor) movement. But my ground wires have corroded in each of my vehicles to the point of breakage so the mystery continues. I’ll have to report back how the 4-6 gauge nEverStart cables endure the harsh conditions in the rust belt.The article suggests braided copper for engine to chassis, but doesn't say why? I assume the concern is moisture can get inside a covered cable?
This attachment should help.@aggrex Where precisely is this ground cable you replaced? I already did the upper one, accessible from the top, near the battery. But the old cable didn't look like the one you have pictured.
IME a good ground is just as important as a good positive.Will a bad ground cause car too not fire and make it throw zero codes
