1 - 10 of 10 Posts
Hi, I have a 2009 Pilot EX-L, some time ago driving on the highway I got DTC P3497 (VTM-4 on, Check Engine On). This continued to happen intermittently for a while, I was driving 1 month, the problem would go away, then it would come back, I also noticed that sometimes just before turning on the ECO mode the vehicle gave a little tug (not always). To correct the problem I bought the Dorman 918-056 solenoid, so I saw many had the problem solved by changing that.
I no longer have the problem on the road nor have I had the jerks when the vehicle goes into ECO mode, but now the code P3497 appears every time I start the vehicle for the first time in the day (cold engine), the engine vibrates a lot for about 5 minutes and after that it stabilizes, then I erase the code with the scanner and I can drive without problems ...
I have read that some solve the problem of the P3497 code by changing the second oil pressure switch (DTC P3400) that goes on the back of the engine, the code is 37240-R70-A04.
I already bought it and I am waiting for it to arrive, I will keep you posted if the problem is solved with that.
Sorry for my english
149737
It's the oil pressure switch that's needed.
149739
I would park the vehicle until it's fixed. It can damage the engine.
Sorry for your troubles. Most of the time replacing just the oil switch will fix it. The assembly is held on with 3 10mm bolts. There is a filter gasket screen that may be clogged.
150061
Or you may want to purchase the whole assembly....
I already changed it, it was the first thing I did, I am thinking of removing the dorman and putting the original honda back
150062
150063
Thanks for reply
Reactions: framirez
The only thing I have not done is change the engine oil, which is a little over the mileage.
I'm going to change the oil, if this doesn't work I'll put the original Honda solenoid back on.
I put the original Honda solenoid back on and now I have no problems, I am going to test it on the road and wait until the DTC P3497 does not return.
Apparently the Dorman solenoid was bad from the factory, because I do not understand how it could cause problems if it is new.
Finally I just changed the oil pressure switch (37240-R70-A04).
150076
150078
Thanks.
View attachment 150076 View attachment 150078
Thanks.
Not a fan of the Dorman. I'm now hesitant to recommend it. Please let us know how it goes.
When I got this code, I replaced the entire Vtec (VVT) solenoid assemblies with spools. I used Standard Motor Products. This required removing the rocker arm assembly to remove spool valve. I currently have 69k miles on these aftermarket parts with no problems.
150080
1 - 10 of 10 Posts
