I've been searching for this scenario and haven't found it elsewhere. Our 2012 Pilot driver's side window will almost never work when the vehicle is started for the first time that day. However, it almost always works after the vehicle has been on for some longer amount of time (~30 minutes) and then will continue to work even if the vehicle is turned off and back on.
I'm not even sure what to test (motor, regulator, switch--I'm thinking it's not the switch).
Any suggestions?
Check the electrical contacts and wiring at all of the connectors. Could be a loose wire, poor/corroded contact, etc.
