1 - 1 of 1 Posts
Hey folks,
I changed 2 PS pump in about 3 months in between(both from 1A auto). My car makes a bad noise and shakes a bit on idle, also when I turn the steering. It's that cavitation noise like when the o rings go bad or it's low on fluid. When I rev it the noise goes away. Now I'm afraid that I have bent the pulley (if that's possible) when installing the new pumps. I would install the pump first and then the pulley. So I think I bent the pulley and now the belts wobbles while spinning. I'm also thinking to try the rebuilt AC Delco pump from Amazon ($146) and also a new pulley from Amazon ($30)
So what do you guys think? Is that possible or have you heard anyone with the same issue?
1 - 1 of 1 Posts
