1 - 8 of 8 Posts
Recently, my 2014 EXL driver's side front door lock will not unlock using the key fob or when putting the vehicle in park. It locks under power but not unlock. My guess is the power lock actuator. Anyone have any ideas? A part number for the replacement part? Thanks!
Does it cycle when you use the lock-unlock rocker switch in the driver's door armrest? If it does, the lock cylinder actuator is working. If no... Does that switch cycle the other locks correctly? The controller for windows and locks lives in the driver's door, part of that rocker switch assembly in the armrest. It receives signals from the separate keyless and immobilizer receiver, so finding what the local rocker switch does is "key" to deciding if the failure is in the cylinder or that module.
The rocker switch used to cycle that lock but not anymore. All the other locks respond when using that rocker.
I'd be looking at the lock cylinder, and also to the electrical signals that go to it while the door is apart.
1 - 8 of 8 Posts
