1 - 14 of 14 Posts
2006 Honda Pilot 2WD
I have over 321,000 miles on my 2006 Pilot. Still running good with the original motor and original transmission. I do oil changes (actually my automotive shop does) every 7000 miles and a transmission flush every 60,000. Brakes, spark plugs and timing belt kit every 100,000. Valve adjustment at 200,000. I use a quart of oil about every 4000 miles. Gas mileage has decreased somewhat over time and mileage. I still get 19-20 mpg. I used to get 23-24 when I had less than 100,000 miles on it.
Premium Member
2005 Pilot EXL- 227,700 Miles
Mannn..... You are Rocking It and an inspiration to us Sub 300k Piloteers!! Thanks for sharing your information! 馃榿馃憤馃憤
Nobili spiritus embiggens peque帽o sparus tyre.
Fantastic. An inspiration, really. (y)
However, because of the thread already started by someone else on the same achievement, I'm afraid to break it to you that you should come back and start this kind of thread when you hit 400.000 miles. Something to shoot for. :)
Post if your Pilot has 300,000 miles
My 08, last of the Gen 1's, is at 185K.
NOW, I'm dong better maintenance like tranny flushes!
I did the first d&f at 184K miles!! I've done 3 d&f's now though.
I have always changed my own oil, religiously, and well before 7K miles.
Usually 4-5K. Synthetic good stuff only.
If you're able, doing your own DIY oil/tranny changes is pretty easy actually.
I feel then I know exactly what went in my motor.
And Congrats on such high mileage!
Reactions: plplplpl
Average Honda Pilot life.
Ready?
120,000 miles
Are you serious?
That's got to include ones that got creamed in an accident and those that got tossed out because a little rust was starting to show up on the rear fenders. Some people can be so fickle. SMH
Or those who never changed their DW-1 ATF or their first gen rad as cheap insurance. Or didn't get a VCMuzzler for a 2008 FWD or a second gen. :p
2005 Honda Pilot EX
I didn't believe in the number. Why it returns as top match is bizarre and surely it ticks off many happy owners.
Congrats to OP. You must've taken good care of them, in return they make you happy and proud.
Banned from wife鈥檚 2005 Pilot LX
Anyone doing replacement of transmission filter in addition to the drain and fill of ATF? If so, at what mileage?
I鈥檓 planning to do that on my wife鈥檚 2005 at its next drain and fill at the 120k mile mark. Currently it has ~119k miles on it so it probably won鈥檛 happen until late winter. It will be the first time the filter gets changed. The filter is not listed/shown in the transmission section of the FSM so I guess Honda expects it to be a lifetime unit (which I don鈥檛 agree with).
I have an 04 Honda Pilot with over 300,000 miles. It's fully loaded black on black.
Welcome to the forum. Glad to hear the Pilot is still running.
Discussion Starter · #13 ·
Update: June 21, 2021
Just turned 346,000 last week. Still runs fine. AC couldn't keep up with the heat, I found the schraeder valves leaking a bit. I tightened them up and added 12 oz of refrigerant and it is good again. This is the first AC maintenance/repair on this vehicle.
Premium Member
Maaannnn that is Awesome!!! Great idea to tighten up schraeder valves- My Low side port is leaking so I鈥檓 going to give that a try today! 馃憤馃憤. Not sure why I didn鈥檛 think of that before 馃ぃ
1 - 14 of 14 Posts
