Avoid Gates kit; go with Aisin kit.so if anyone has info help in this I will be thankful for example these 3.5 engines have a hydraulic timing belt tensioner that prematurely fails and is unpredictable so if a solution to this is available then please speak up. Thanks
I installed the Aisin timing belt kit with water pump. Lasted 7000 miles until the hydraulic tensioner leaked/failed and the new timing belt broke. I went to Napa and bought the Gates belt and hydraulic tensioner and installed it myself. I figured if the Aisin failed then I’ll try Gates at Napa. Only been 500 miles so far so we will see. I seen a YouTube video with a guy that had a spring loaded tensioner but haven’t found any info on cross reference to my 05 3.5 Pilot yet.Avoid Gates kit; go with Aisin kit.
That really doesn't seem right. With all due respect, how can you be sure it was installed properly? It can be a tricky job, even for some mechanics.I installed the Aisin timing belt kit with water pump. Lasted 7000 miles until the hydraulic tensioner leaked/failed and the new timing belt broke.
I can’t be sure other than he is a certified mechanic who works at a dealership and does side work for extra $. I have theories that include old stock, improper install of the belt as in making sure the non tensioner side was installed first without slack so tensioner side pin can be pulled to take up slack.Also when I took it apart I noticed that I only had half of the rubber seal that goes in between the lower cover and the upper two covers so if the rubber seal pinched inward when he put it back together then it could have fallen into and in between the belt and crank sprocket and caused it to break. It did have rubber dust inside the cover. Theories but I can’t say 100% for sure that’s why I did it myself this time. I still would prefer a spring loaded vs hydraulic tensioner if it is safe to do so.That really doesn't seem right. With all due respect, how can you be sure it was installed properly? It can be a tricky job, even for some mechanics.
Update on for info on a spring loaded vs hydraulic timing belt tensioner. The YouTube video is BundysGarage. I still haven’t found out what Honda model 3.5 engine application this spring loaded tensioner is from or if it is a usable crossover part so beware of that at least until I can update the info.I can’t be sure other than he is a certified mechanic who works at a dealership and does side work for extra $. I have theories that include old stock, improper install of the belt as in making sure the non tensioner side was installed first without slack so tensioner side pin can be pulled to take up slack.Also when I took it apart I noticed that I only had half of the rubber seal that goes in between the lower cover and the upper two covers so if the rubber seal pinched inward when he put it back together then it could have fallen into and in between the belt and crank sprocket and caused it to break. It did have rubber dust inside the cover. Theories but I can’t say 100% for sure that’s why I did it myself this time. I still would prefer a spring loaded vs hydraulic tensioner if it is safe to do so.
Another update on the Hydraulic tensioner on the 03-08 pilots. As I said I had a hydraulic tensioner fail after only 7000 miles and have read about many of these failing prematurely. I found the model and year of the Honda with the SPRING tensioner. It is a 2000 Honda Accord. O’Reilly auto parts has it and the part number for the Hates brand is :T43198 $112 and a Dorman: 420-100 $73. Please note that I have not verified the fit over to our Honda Pilots so if you try it it is at you own risk. I WILL be doing this within one month and I will update for anyone who is interested. If it works like the guy on the YouTube said then it will put a stop to the premature failure on the hydraulic tensioner that always leaks and fails. Till then...Update on for info on a spring loaded vs hydraulic timing belt tensioner. The YouTube video is BundysGarage. I still haven’t found out what Honda model 3.5 engine application this spring loaded tensioner is from or if it is a usable crossover part so beware of that at least until I can update the info.
Interesting. Keep us posted. We would Hates for it not to work.the part number for the Hates brand is :T43198 $112 and a Dorman: 420-100 $73. Please note that I have not verified the fit over to our Honda Pilots so if you try it it is at you own risk. I WILL be doing this within one month and I will update for anyone who is interested.
Nice! $31 bucks ! I knew there were cheaper options out there but just hadn’t got around to checking. Thanks!Interesting. Keep us posted. We would Hates for it not to work.
GATES T43198 Timing Belt Tensioner | RockAuto
RockAuto ships auto parts and body parts from over 300 manufacturers to customers' doors worldwide, all at warehouse prices. Easy to use parts catalog.www.rockauto.com
Be careful on that CRV. They have had some major problems of gas mixing into the oil and destroying the engine . I don’t remember the years that are affected but you can goggle it or go on YouTube and look for it. Not trying to scare ya. Just want to make sure.218000 on our 2005 Pilot. Original Engine and transmission. Just normal maintenance except for a radiator replacement at 100,000. Luckily that was caught by the dealer before we got the dreaded radiator fluid in the transmission problem. Have a few rust bubbles by the rear window wiper but thats it. Just bought the wife a 2016 CRV and I took over the Pilot. Modernized it a little bit with an aftermarket stereo with Bluetooth so I can do hands free calling now. Hope to see 300,000 in this car.
Yeah that was happening to the 1.8 turbo's in the newer models. Ours just hast the trusty 2.4 no turbo.Be careful on that CRV. They have had some major problems of gas mixing into the oil and destroying the engine . I don’t remember the years that are affected but you can goggle it or go on YouTube and look for it. Not trying to scare ya. Just want to make sure.
2005 Pilot Exl bought new . 234k Ive replaced the starter and a cooling fan motor. Just regular maintenance otherwise. I neglected to change the timing belt at 213k and paid dearly when it shredded. So everyone be sure you change your timing belt at the recommended mileage.Post if you have 200k miles on you pilot and no issues, original engine and tranny!
Add your cautionary tale to this thread:2005 Pilot Exl bought new . 234k Ive replaced the starter and a cooling fan motor. Just regular maintenance otherwise. I neglected to change the timing belt at 213k and paid dearly when it shredded. So everyone be sure you change your timing belt at the recommended mileage.
