2012 popping noise in front end when braking hard and take off from a stop. Replaced stab links to no avail. Very annoying please help. Lower arms no leaking and look real good. Thanks
You have to check every bolt in your suspension to make sure they are all torqued properly. Same with any rubber parts for wear. Struts, LCAs, sway bar end links, sway bar brackets on the subframe, etc. I'd also hit the caliper bracket and caliper bolts for torque as well. If all of those check out look at motor mounts. Possibly subframe bolts. Just grab all of your wrenches, ratchets and sockets and have a good time checking everything.
The only other thing can think of as "known" failure points on the early 2nd gens is the lower control arm bushing, give that a good look first but it will be obvious visually if that has failed.
It’s looks good and rubber feel supple,,,but I will poke prod and reef on everything under there.
