As many know, Honda has decided to make it incredibly difficult to swap out the factory audio head for something nice and modern. Not only the trim panel itself is non-standard, curvy and actually slightly narrower than a typical car stereo, it also integrates a number of non-audio related features, namely:
Climate sub-display above the audio controls. This is kinda the biggest inconvenience.
Trip computer display- mostly fluff info.
Various diagnostic functions/setup menus. Only needed once in a blue moon.
One option that I see most commonly - and one that I went with myself - is to leave the OEM audio unit in as-is and still powered, and mod the top of the dash to install the new head unit in place of the display. That is what I did in my 2013 EX, and am quite pleased with the results. My thread about that overhaul, as well as a thread by DMG about a similar mod can be found in 'Audio and Electronics'.
However, I kinda been thinking about potentially an alternative method: retaining factory display, and partially gutting the factory head. After all, large part of its volume is occupied by the CD module. Because of how the trim is done, the only units that really would 'work' are the folating screen ones: a single DIN body, and a touch panel attached to it.
You can find the EX/EXL audio unit for like $30 on ebay, so I ordered one:
Musical instrument Electronic instrument Audio equipment Wood Musical instrument accessory
The Navigation head is a fair bit different in configuration, and the cheapest I could find it on ebay for is like $150. I think I'll pass for the time being. In any case, from pictures, the internal construction appears fairly similar.
Camera accessory Cameras & optics Bumper Motor vehicle Automotive exterior
Looking from this side, one can see that there is a front module housing the controls, bottom module with the electronics, and a top module for CD.
Once it all is disassembled, CD part connects to main board with a single ribbon cable, and looks like it can be removed without much fuss. Once that is done, you got a lot of room to work with:
Passive circuit component Circuit component Hardware programmer Electronic instrument Computer hardware
But the big problem is the controls module. That is the part where most attention will need to be paid:
Passive circuit component Circuit component Green Electronic instrument Hardware programmer
This is its look from the rear. Two black connectors on the bottom are where it attaches to the main board, and the small separate module on top connected by a short ribbon cable is the climate controls display.
Now the idea here is to retain various non-audio features of the audio unit. The BEST option here is one of Pioneer modular units, such as
The screen mounting brackets would need to be modded a bit, but the whole screen can be installed without altering the front circuit board at all, entirely through the CD slot. Anything else would require some cutting.
Question is: what CAN be cut? This controls PCB may look complex, but really most of it is leads going to various button contacts and illumination LEDs. The real big cheese are the leads going to the climate controls connector.
Circuit component Rectangle Hardware programmer Passive circuit component Electronic component
A bit of circuit analysis shows that the red rectangle part can be cut out - this would allow installation of pretty much any floating screen head - Boss, Sony, Alpine, Jensen etc.
There is another issue, however. If you want to use stuff like trip computer etc, you need to be able to unlock your audio unit after battery disconnect. For a native head, that just means holding power button for a while. If you gutted a used one from ebay, it means entering a code. Which KINDA means your power and preset 1-6 buttons need to work, and they are right in that cutout area.
Circuit component Rectangle Hardware programmer Font Electronic component
A bit more poking around identifies 7 lead groups going into the chip that service all the presets and power button. One could put together a small sub-PCB with 7 micro buttons, connected to the main PCB via 7 wires - that would allow use of the number buttons. Technically, same can be done for climate display as well - just run some wires from black connectors on bottom to the white one on top - then pretty much entire middle portion of the PCB can be removed.
When I have a bit more free time, I plan to actually carry this through on this unit, to see if it indeed retains desired functionality.
Discussion Starter · #2 ·
A short list of extra supplies:
To create a small separate PCB with 6 preset and power button, to connect to the main PCB via 7-lead ribbon:
A longer 12" ribbon cable to use instead of the short one connecting the climate display module:
14-position, 1.0mm pitch flex ribbon.
A 14P connector to attach it to on the PCB.
One can cut out small PCB section with the original connector and use that, but I want a spare or two in case I mess up, and I want to test pin-to-pin connectivity between old and new connectors before cutting it.
Looking forward to see how this turns out. Was looking at the Pioneer unit and by it useing the cable connection we would only have to fabricate a mounting bracket for the display. If I’m correct
I got the parts from DigiKey, but this weekend, other matters intruded.
The result I am trying to achieve is essentially a full singleDIN opening (about 2x7 inches). Such arrangement would allow to mount any floating screen head unit.
Was wondering will the A/C controls still work on the 2012 EX-L if we just remove the radio, I'm leaning towards buying the mounting bracket for the 2009 model and mount it that way I mean,
If all I stand to lose is a digital visual of the temp I can deal with that as long as I can still control the heating and cooling. Keep us posted on your progress and as always thank you for your research, time and effort.
