Hey all,
First thing, get yourself an MDX brochure AND a Honda Pilot brochure! Ok, next, look through the brochure to find the "HP/Torque graph". Now, compare the two graphs...you will see something odd!
Just FYI, it was assumed by many (including me) that the Pilot's engine and MDX's are the same, with slightly different tuning. It has the same displacement, compression ratios, and design. However, the biggest difference is that the Pilot's engine uses REGULAR fuel (similar to the new Odyssey's engine). MDX uses premium. On paper, MDX spec shows that the torque is 245 lbs from 3000-5000 RPM. With the Pilot, torque peaks at 4200 (i think).
However, if you look closely, the range from 3000-5000 is very similar in both graphs. Now, look at the torque BELOW 2000 RPM...do you notice anything?? Yes, the MDX torque drops off rather rapidly in comparison to the Pilot's...that is, at low RPM, the Pilot has significantly MORE torque than MDX!
Am i imagining things?? Do you guys see it too??? Is this a mistake by Honda printing people???
Strange....
Strange....
