1 - 13 of 13 Posts
Hello all. New to this forum. So this morning around 2am my 2017 pilots alarm kept going off. It is parked in the garage so I didn’t know what was going on. I went to turn it off and it just started clicking off and on as if it wanted to turn itself on. You can hear the fuel pump starting and everything. It clicks off and on by itself. I checked the key FOb battery and it’s not that. The only way to stop is removing the battery from the truck. Any idea what I should look into?
If it still does it with no batteries in the both remotes i’d say it might be a bad mass somewhere.
There could be a relay stuck somewhere. Is it a Touring model or an EXL?
The Touring models have an auto stop start feature or it could be something to do with the remote start. Did you try reconnecting the car battery again to see if it is still doing it? It may also be a software glitch which would require a visit to the dealer if it doesn't go away.
just turned it in again and now it’s giving me the keyless start error message.
It’s an EXL btw. Dash says keyless start system problem. Battery is good according to my local auto parts store. Just checked
Could it be the switch module? Just got the keyless start system error message on the dash
Might be the start stop button that has issues. I just replaced mine due the Keyless Start System Problem. I was not having the same symptoms that you are having though. It's an easy DIY repair and an $80 part if you decide to go that way.
With given description it might be anything- the module the button or even bad radio signal from nearby.
I’d suggest to check if the car checks security (key fob in the car or remote start command) prior engaging the fuel pump (you said you was able to hear it). This will help to narrow down search for the failure piece. Try to disconnect the start button to check it as well.
Also fo you have a code scanner that can read remote start code? It might be very helpful.
Btw yours should be still covered by the warranty why bother to diagnose yourself?
But with bunch of modules going on/off bad mass would be likely the issue.
Can you post what the problem and solve ended up being? My 2016 Pilot EXL did this exact same thing last night at 1:15am. Scheduled to go to the shop tonight, but would love to know what to expect.
There is a warranty extension on the start/stop button issued by Honda a few months ago.
Just thought I’d follow up here. Dealership replaced my Remore Access Control Module. That fixed it. I was out of warranty so it cost $650.
Note for anyone else having this done: afterwards they will need to update every key fob, and they’ll need them all together. I had to bring them all in as a second trip because they forgot to tell me that before I picked it up. No biggie, just maybe save someone else that extra trip.
1 - 13 of 13 Posts
