My Pilot 2019 27,000 kms recently started to change gears from drive to parking when I make a stop, this happens when the ralenti mechanism is turned ON, I´ve taken the vehicle to Honda services and they haven´t found anything when scanning the vehicle, is somenone experiencing the same? Does anyone know what the problem could be?
If you are still having this issue, determine if your door thinks its opening on a stop. This should be indicated on the dash. The Pilot will put the transmission in park when the drivers door is opened.
