Hi All,
Anyone have any idea why my 2009 Pilt with 155K miles sputtered and died on the highway. Won't start or turn-over. Codes: P0300 all the way to 301-306
I'm thinking it might be
EGR ports under valve cover-clean-
EGR Valve
Idle air control valve
PCV valve
If so please email me at [email protected] and give me an estimate on what you think I need to do to get it running again.
2005 Pilot LX
Have you checked the battery voltage?
Start with the basics: does the engine have fuel? How about spark?
Fuel: empty tank? Fuel pump failed? Clogged fuel line? Cut or broken fuel line?
Spark: battery or alternator failure ? Ground cable failure? Fuse or relay bad? Crankshaft position sensor bad? Camshaft position sensor bad?
All those codes relate to fuel I agree with STMech on this one ..
Hi All,
EGR Valve
PCV valve
It won't turn over? I would start with the battery.
Not sure if im too late, but sounds like the alternator went bad and killed the battery.
