1 - 2 of 2 Posts
Hi all,
Looking for some help to diagnose A/C squeaking noise.
  • 2012 Honda Pilot
  • Only Hear squeak when A/C is on
  • intensifies when I hit the brakes and momentum shifts
  • I have not made any recent changes / flushes to system to say there would be an air bubble
Attaching link to a GDrive file if anyone cares to hear the sounds on the video. (Let me know if it doesn’t work, but I did get a link for access!)
appreciate the help / expertise!
"Only Hear squeak when A/C is on"; does that mean the noise comes and goes when you manually press the A/C button on/off, but the HVAC is otherwise on and cabin fan is running?
Does the noise change in any way when you manually increase/decrease cabin fan speed?
Noise better or worse if you switch to fresh air vs RECIRC?
Is the noise worse/better at any particular speed?
Noise present when you are stopped?
Is the noise louder within the engine bay (hood raised) when the A/C is running?
1 - 2 of 2 Posts
