Hi piloteers, im owner of 2009 honda pilot, some days ago low oil pressure light start blinking and after that check engine light came up with VTM-4 & VSA light also. vehicle start doing rough shift change.
after turning engine off and than switch on again, all lights went off but check engine still on.
checked transmission oil level, and it was fine.
now some time vehicle doing same and problem goes after restart, please help as im living in oman and local garages has no experience of american vehicles plus HONDA charges alot here for even code reading.
any one face same issue please guide me so i can catch exact problem.
Really need the trouble codes.
How many kms?
Have you checked the engine oil level?
Has the valve clearance ever been checked/adjusted?
When was the timing belt and tensioner replaced?
Did you check the engine oil level or just the transmission fluid.
If the indicator looked like this...
148845
it is the low engine oil light.
Is the engine oil level is correct, and the correct oil viscosity?
The only advice I could give is my regular maintenance list.
  1. Disable the VCM.
  2. Air filter New/Clean installed correctly
  3. Air intake hose, no air leaks, clamps tight.
  4. Mass Airflow Sensor New or Clean
  5. Spark plugs New/Clean. NGK Laser Iridiums Only
  6. Spark plug tubes no oil inside.
  7. Coils good. No oil
  8. Replace PCV valve
  9. Replace EGR valve
  10. No O2 sensor codes
  11. Use Full synthetic oil 0w20
  12. Use minimum 87 octane fuel with injector cleaner.
Need trouble codes for more direction.
Has the timing belt and water pump been replaced? Every 7 years or 100,000 km for extreme conditions.
Reactions: aggrex
