1 - 16 of 16 Posts
2021 Pilot SE AWD
I have a 2021 Pilot SE AWD and I’m using the Veepeak OBDcheck Bluetooth scanner and OBD Fusion app. All the preloaded PIDs work fine but I can’t get the user defined PID for the transmission temp to work. I have searched this forum extensively and tried all the different suggestions from previous posts before asking. It’s possible I have a typo or other error but I’m starting to wonder if it has to do with my transmission being the 9AT and not the 6AT. I’ve not found any posts that this was used on 9AT. Below is the PID settings I’ve entered. Any insight would be appreciated. Font Screenshot Technology Multimedia Software Font Screenshot Multimedia Darkness Number
Try the Car Scanner app. I have the 6AT but the standard transmission temp PID worked fine for me, no custom one required.
2021 Pilot SE AWD
I’ll try that, thanks. I’ve sent an email to customer service for OBD Fusion. I’ll update if they have an insight.
Been reported before that the 9 speed does not show transmission temp using a scanner. So far I haven't read of anyone who has successfully done so with anything other than the 6 speed.
This is what I know works on my 6 speed. Looks like you may be missing a couple of 2s?
OBD2 Mode and PID: 222201
Long Name: Transmission Temp F
Short Name: ATF Temp
Minimum value: -40
Maximum value: 300
Scale factor: x1
Equation: AA*(9/5)-40
Overrides PID: "Does not override any PIDs"
2021 Pilot SE AWD
That’s what I was afraid of. Thanks.
2021 Pilot SE AWD
OBD Fusion customer service replied with the following:
“It's likely the PID definitions are different for the different transmission types. What custom PID were you trying to use?”
Hopefully they can help. If I get it figured out I’ll be sure to post what worked.
What you're going to have to do is step up a level from the basic consumer spec OBD2 set up to a Fox well Scanner that can read zf 9 speed, Honda CVT etc trans temps.
I believe some folks over at the Ridgeline forum are monitoring 9 speed TFT.
Reactions: Pilot EX-L 2021
I was looking down at my trans from atop thru to it and noticed a German mfg plate affixed to it next to the ATF 3.x tag. Are our 2021 Pilot EXL transmissions German made?
@anthonysquire I use the Car Scanner app with my Veepack and it reads transmission temps of my 9 speed.
Curious if anyone would like to give these a try on the ZF9 tranny.
Works for me on 2020 Ridgeline w/ ZF9
Some specifics please.....high/low, driving conditions, towing, ambient temps, etc.?
When I towed my SylvanSport GO two weeks ago through the Smokies, the trans never got above 190, and coolant never got above 197. Ambient temps were around 85-90 I think. I'm sorry I didn't pay more attention, but it I was satisfied on how the car performed while towing over all. I just need to get adjusted to the way it tows...this trans is so different from the one in my 2004 Pilot that I towed with previously.
1 - 16 of 16 Posts
