ALCON,
need pictures of pilot headliner after removing RES
Reason: Currently working on a conversion of a 2012 EXL-NAV-4WD
need to see how RES is mounted and if there is an additional bracket needed or not
137014
137015
sorry for the dirty car seat lol....
here you can see I'm 90% done with the OEM RES wiring conversion project
but need a good picture of OEM RES bracket in a 2009-2015 honda pilot
NOT INTERESTED IN AFTERMARKET AT ALL
thanks
PLEASE.....
For those with 09-2015 OEM RES...
If you have time and good gentle hands and skills not to mess up your system
by removing the OEM RES in order to show the roof/ceiling area
I just need a couple of clean pictures of that area...
137181
137182
these are from a 2009 odyssey...in a nearby junkyard
like I suspected honda made an additional bracket for RES
However, this bracket doesn't fit in any 09-15 pilot without drilling on the sunroof rails
137252
09-2015 honda pilot with RES sunroof is confirmed to be different than all others without RES
Here you can see the additional OEM brackets added
