1 - 10 of 10 Posts
I bought sensor for my Honda it not the whole part just the black sensor can I just replace the sensor and if so ihave to punch in code after I replace it or just connect it
Miss our 2005 Pilot
Welcome to the forum.
What sensor are you replacing?
Miss our 2005 Pilot
Here is the assembly drawing for the Pilot. If you go with OEM it looks like you must buy the assembly.
With that said, if you can take the sensor off your existing accelerator module you might find the part number of the sensor imprinted on the housing. Then do a google search to see if you can find just the sensor for the Pilot.
Reactions: plplplpl
Miss our 2005 Pilot
So I can replace just the sensor and not the whole assembly the sensor is under 25$and the whole assembly is $150 than
Possibly. As I mentioned above, it will require some investigation on your end.
1 - 10 of 10 Posts
